steel ground effects/extended rockers
Not much of anything done this year. Did partially complete making flush mount quarter windows, will post pics later.
Started making stainless flush mount handles at the top of the doors.
Did a little fender & quarter panel redoration against a guard rail after someone cut me off in traffic & a rear brake cylinder failed.
Pulled some of it out for now.
Damaged the real fender flare & quarter, got most of it out from inside bed wall for now.
Won't have time to work on till probably next year .Been trying to improve my area to work at right now
  • Friendly
Reactions: CartmanTD
So, since I have damage to repair, I'll make improvements while at it. Will make flush fender vents to replace the 79' z-28 vents.
Looking at designing a different Camaro nose. May buy a fiberglass 2015 nose from duraflex. Not known as the best quality, but I'm chopping it up anyways & will strengthen it.Also planning on making it have some of the look of the new2016 nose.
2105 duraflex nose.
2016 Camaro ss
overlay drawing showing some of the changes to make the 2015 look similar to the 2016.
The 2016 headlight daytime running lights are a big part of the look. Need to figure out how to make my handmade lights have the drl lights. Sure can't afford to buy em.
Car is definitely cool ! I'm confused as to how the plenum set up is going to work, please elaborate. Is that at Tower Shoppes?
Haven't got back to the plenum project in well over a year. It's just sitting on top of the old ls1 intake in the pics. Will have a 2 into 1 connector to throttle body. Picture by orange truck is main st, jacksonville , fl if that's what you were asking.
