steering shaft
scarborough
306
66
starting to hoard parts for spring time for my 87 cutlass . i saw this steering shaft on eBay was wondering if this is the one everyone is using for their swap.
$49.99/ea
Lower Power Steering Shaft compatible for Jeep Cherokee 1984-1994 compatible for Jeep​
Low_Bridge
Jan 22, 2014
69
13
Backwoods
Ordered one yesterday from a different vendor, same part number off thEbay~ Should know more by the weekend ~ The specs on the one I ordered length seemed right ~
Rt Jam
592
583
Ontario Canada
You need to know what is under that boot. A G body steering shaft needs to easily float in and out. I don't mean it can shortened in an accident or you tap it with a hammer to install it to the correct length.
Look at how the OEM shaft is, they are sliders in a greased coupling. This allows the separate body and constantly flexing frame to not allow the steering column to load the bearing in the steering box.
I know many people have used the unibody Jeep steering shaft but there is a reason why the OEM shaft can float to correct length. Comparing a broken rag joint to a universal joint is a poor comparison. New to new, one is not tighter.
Low_Bridge
Jan 22, 2014
69
13
Backwoods
This one floats & dropped right in.
I'm on the right track?
scarborough
306
66
nice to know. will be placing a order after the holidays, have to get the long Christmas shopping list in first.
just wondering how to go about post picture of my project on the site. i know how to cut and paste picture off web, but haven't figured how to download the ones off my phone.
Low_Bridge
Jan 22, 2014
69
13
Backwoods
I clicked on attached files & uploaded from PC
Built6spdMCSS
5,797
9,670
Florida Beach
Look for that, find photos, attach, insert.
Low_Bridge
Jan 22, 2014
69
13
Backwoods
actually rt jam the top side is only clamp tight, no notch for the retaining bolt. kinda concerning but i tightened her up & used locktight on the top bolt
sure i could engineer back up retention (?)
