Supreme Speed Salon (87 T Top Salon build)
I think so but it may require different length pushrods. I did it will stock slightly modified heads and noticed a slight change but your heads are much better. Basically you want as minimal movement across the tip, opened to closed and the pattern as close to center as possible.
Reactions: SupremeSpeed
Yeah I figured that much more lift longer rods gotcha👌🏿
Hey guys I would like your opinion on the color combo I've chosen. Also at some point I plan to add a functional dual scoop hood. So I also would like your opinions on which color to go with on the top of them. The 442 will not be added, just thinking about using the color on top of the scoops, or the lighter shade on the bottom panels. 🤷🏿‍♂️
I like it, something different. I say look into the straight scoop VFN W25 style dual scoop fiberglass hood styled after the 1970 hood. US Body Source also makes one with angled scoops which don't line up with a G body Cutlass lines.
I’m digging the colour scheme you’ve chosen. I’d say scoops should be the same colour as the hood.
I agree, maybe the right colour pinstripe around them.
