Supreme Speed Salon (87 T Top Salon build)
8
81cutlass
2,266
Western MN
Mind sharing some specifics about the heads combo on those? I know they are eldelbrock BBO heads, but are they milled, what springs & rocker setup, ect.
Thanks!
It looks awesome!
SupremeSpeed
SupremeSpeed
510
GA
Thanks!
It looks awesome!
I had a shop order and build the motor. Its bored .030 over full roller. Rockers arms are 455 7/16 1.52. All Comp Cams pushrod and rocker arm kit as far as I know.
olds307 and 403
olds307 and 403
5,877
Melville,Saskatchewan
Weird, factory ratio is 1.6, wonder what those rockers are for sbc?
olds307 and 403
olds307 and 403
5,877
As long as the pattern is good and pushrod length is right, they should work fine. You will have less lift than advertised as Olds cams assume a 1.6 ratio.
Reactions: SupremeSpeed
SupremeSpeed
SupremeSpeed
510
GA
Ok I see. Do you think I would notice a difference? More lift seems better but IDK 🤷🏿‍♂️
olds307 and 403
olds307 and 403
5,877
I was just going through this thread but haven't found the cam specs, what are they? Your heads move serious air, around 260 CFM and 190 exhaust with a much better chamber design. I say 1.7 rocker arms but it depends on the cam, those heads will take .575" lift.
TURNA
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
11,010
Socialist NY
What does the cam call for?
olds307 and 403
olds307 and 403
5,877
  • Wow
Thread starter Similar threads Forum Replies Date
Eddie Cutlass CUTLASS Replace TPS or Carb? Fuel / Air / Boost / Emissions 48
Eddie Cutlass CUTLASS NEW RIDE: ‘85 Cutlass Supreme Brougham Sedan. Oldsmobile Cutlass / 442 / Hurst/Olds 5
Eddie Cutlass Greetings from San Diego New Users 9
8 CUTLASS 84 supreme 305 swap (need help) Engine / Swaps / Driveability 27
P 80 Cutlass Supreme T-Tops Only Question Oldsmobile Cutlass / 442 / Hurst/Olds 5
P 1980 Cutlass Supreme Core Support G-Body Parts For Sale / Trade 2
P 1980 Cutlass Supreme Driver Side Fender G-Body Parts For Sale / Trade 0
P 1980 Cutlass Supreme Passenger Side Fender G-Body Parts For Sale / Trade 0
nickonometry My 88 Cutlass Supreme Oldsmobile Cutlass / 442 / Hurst/Olds 14
P 1980 Cutlass Supreme Front Bumper G-Body Parts For Sale / Trade 0
P 1980 Cutlass Supreme Rolling Chassis G-Body Parts For Sale / Trade 7
SmokinJoe cutlass supreme upper radiator hose strap to fan shroud Oldsmobile Cutlass / 442 / Hurst/Olds 6
DoctorSwain V6 engine for an 83 cutlass supreme Wanted 2
DoctorSwain Engine Swap for 1983 Cutlass Supreme Engine / Swaps / Driveability 35
T CUTLASS Unmolested 1986 Cutlass Supreme Brougham strange electrical issue Electrical / Ignition / Starting 0
Quick CUTLASS 86' cutlass Supreme 5800 New Users 0
J Cutlass Supreme temp gauge erratic Oldsmobile Cutlass / 442 / Hurst/Olds 1
nickonometry 1988 Cutlass Supreme Question Oldsmobile Cutlass / 442 / Hurst/Olds 5
J 83 cutlass supreme 307 y code- power steering bracket Frame / Chassis / Suspension / Steering 6
D 86 cutlass supreme 22s fitment issue OFF TOPIC 2
A 557 mile 88 Cutlass Supreme General Discussion 41
M 1985 cutlass supreme New Users 1
azmusclecar 1979 differences between Calais and Supreme model ??? Oldsmobile Cutlass / 442 / Hurst/Olds 10
mickeypowa Cutlass supreme Accident General Discussion 100
JAMCAR223 What's the deal with the Jegs crossmember saying " Does NOT fit Cutlass Supreme" ? Transmission / Rear End / Driveline 4
Emhendo Speedometer Cable 1986 Cutlass Supreme General Discussion 15
1-sic-83 “COFFEE TALK” 83 cutlass supreme Oldsmobile Cutlass / 442 / Hurst/Olds 34
Rigo’s87 New member New Users 5
Dayzedandkonfuzed 1985 Cutlass Supreme G-Body Cars for Sale / Trade 14
CuttassG 1978 cutlass supreme brougham motor swap General Discussion 10
R 84 Cutlass Bolt Pattern? Wheels / Tires / Brakes 2
86HotRodSS a few more pics of my Olds Cutlass Supreme Brougham Oldsmobile Cutlass / 442 / Hurst/Olds 4
N My newest refugee 1983 cutlass supreme Oldsmobile Cutlass / 442 / Hurst/Olds 20
ramirezantonio1409 New Member 1986 Cutlass Supreme New Users 12
Emhendo What Kind Of Power Steering in an 86' Cutlass Supreme? Oldsmobile Cutlass / 442 / Hurst/Olds 56
Emhendo How Much Oil Does an 86' Cutlass Supreme Hold? Engine / Swaps / Driveability 11
MadMonte 4 Speed conv. w/Hyd. Clutch Transmission / Rear End / Driveline 11
C Factory 4 speed owners-looking for a measurement Transmission / Rear End / Driveline 47
4 CUTLASS high speed vibration Wheels / Tires / Brakes 8
S CUTLASS No high speed on defrost/heat Cooling / Heating / AC 7
gnvair Did any of you see the 79 5 speed set up for sale? Oldsmobile Cutlass / 442 / Hurst/Olds 16
Scotty t MALIBU 78 4 speed Chevrolet Monte Carlo / SS / Malibu 5
gnvair Factory A body 4 speed Hurst shifter on Ebay Chevrolet Monte Carlo / SS / Malibu 0
69hurstolds CUTLASS Power Window wiring diagram adding relays to speed up the window motors How-To's / Knowledge Base 33
gnvair Another odd ball 4 speed Malibu for sale (not mine) Chevrolet Monte Carlo / SS / Malibu 20
gnvair MALIBU Installing a Super T10 4 speed in place of a Saginaw 3 or 4 speed in a 78-81 A body without moving the original shifter hump. How-To's / Knowledge Base 22
Wageslave Best front end changes for high speed stability? Frame / Chassis / Suspension / Steering 20
Chevytruc1658 3 speed Lightning Rod Shifter Transmission / Rear End / Driveline 6
DoubleV 4 speed manual shifters General Discussion 5
D speed bleeders Wheels / Tires / Brakes 3
Similar threads
