Two weeks later, I'm trying to keep making progress on the truck. I got the bad tire pressure sensor replaced on 8/17. When I put the current tires on the truck, one of the wheels was curbed. I replaced it but rather than discard that wheel and tire, I just threw it in the bed and tied it down with a ratcheting strap. That way, hopefully I never have to get the spare down from under the bed on the side of the road, again. In this case, that wheel/tire came in handy. I swapped it for the right rear, which had the bad tire sensor. Thank I took it to Discount Tire and had them swap the sensor for me on the loose wheel. It was a good experience. I find the less I give them to do, the happier I am. It's nice not having the TPMS light and error message on all the time.
Yesterday I put the rear up on stands and replaced the Vapor Canister Vent Valve. I've done it before, but it's probably been seven or eight years. It isn't a bad job. Just dirty. Thank you GM for changing the connector on the vent valve so now I need to spend $42 on an adapter harness. Thankfully the NAPA at the front of my neighborhood had it. It was worth the high price to have it now and be able to move on.....
Thank you GM for changing the port size for the vent hose from 5/8" to 7/8" so now the 5/8" heater hose that I have running all the way to the front of the transmission, per the prior TSB, won't fit. Delco gives you the rubber part in the picture below which adapts it from 7/8" to 3/4". It took some serious digging but I had a 5/8" to 3/4" hose adapter on hand......
This not fitting crap was starting to make me grumpy at this point. I hate it when they redesign the part and now it's one size fits most. Here it is on the truck since pics or it didn't happen....
I cleared the code. I'll know in a week or so if this fixed the EVAP code. I can say I made the mistake of putting the old vent valve in my mouth and blowing/sucking on it. I ended up with a mouth full of dirt. It seemed to be wide open, which can't be right so I'm hoping this was the problem.
Sean and I also took the new bumper cover over to the painter's house later that afternoon. I'll probably work on getting the powdercoat redone on my grill insert between now and when I get the painted bumper cover back. If I had it to do over again I wouldn't have bought the bumper cover and would have just lived with the one on the truck. But, I bought it and left the box at the dealership so I'll go with replacing the one on the truck.
Progressive paid out $586 on the claim. I thought about fighting for a few dollars more but I decided against it. Their estimate proved to me why I didn't want a shop to fix it. Aftermarket parts. Refinishing the bumper cover on the truck. Very cheap. He didn't have the bent up center bumper brackets on his estimate so he would have had to add those, but anyway, done deal.
I guess that's it for now friends. Thanks for following along.
