Thanks for the tips!
I drained the transmission yesterday. Hopefully, the torque converter won't have much fluid inside.
The drive shaft and all horizontal bracing assembly bolts have been removed. Two bell housing bolts accessible from the engine compartment have also been removed. Otherwise, all cables and cooler lines have been moved out of the way.
My neighbor loaned me a motor cycle/ transmission jack. I am hoping a 2x12 bridging between both legs of the jack will allow the bell housing to be taken completely loose without drama. The center bolt at the tail of the transmission extending thru the cross brace has me be a bit concerned. Can this be tapped out or does the transmission need to be lifted in order to remove the bolt or brace? Does it make sense to remove the transmission tunnel stiffener?
Thanks for all of the assistance. I almost have the parts out!
