Now all the offending glue & gasket material has been removed. Looked over the carb section in a few of my servive manuals & found out whoever worked on it last didn't even put the power piston/primary metering rod group together correctly. The metering rods were on top of the main body/air horn gasket instead of being attached to the power piston. So I think I figured out what's needed is the rebuild kit, a choke unit, a corn friendly accelerator pump piston, & the lower choke rod lever.
