shotgun said:The metric 200 had the same first (2.75) as the OD trans listed above. Going to them will not help off the line.
If it is working right (no slip, shifts firm, TV cable set right) it is not your problem , yet.
Find out the rear ratio.
Get the engine right.
After that you will have to start trans shopping.![]()
pretty sure engine is right . going to take it into a shop this week for them to fine tune carb and whatnot . trans does hesitate shifting a little and if i dig into it , well its a no go lol . i will do the tape trick on drive shaft and tire as stated above tomorrow . im guessing thats going to tell you so you can tell me what rearend is in it ?
