The Bonny Project
275 60 15"?
Like those rims ! Kinda curious as to what the back spacing and rim with is. What happened to the hub cap look?
They are just trial fit tires n rims.
I’ll be going hubcaps trust me.😁
That’s a powder coated T rim off my ‘87 Ltd
BS is 4”
The tires are close to frame on the Bonneville, so I’ll probably use a rim with 3.75” BS
Reactions: fleming442
If those are "T" type rims they are 7 wide and 3.75 bs . If that is the tire you are going to run an 8 inch rim will give a better foot print and you need 3.5 bs
If you're interested...
Reactions: ssn696
The back of these T rims are stamped 15x7 JJ 4.0
I assumed the 4.0 was the BS
I understand the tire will land on a 8” better
I actually have the same tire mounted on a 15x10 Weld for my GS
