Thinking about it, you'd probably want the suitcase weights to hang off the front. That will keep it from trying to lift the front with recoil.Now we be talking here. Only modification I can think of is to modify the trigger using a bell crank on a pivot and a rod with a couple of heim ends attached to a pedal to make it foot actuated. Any plans to add more more weight out back to compensate for the push back when it is fired?
The M249 SAW is 5.56 NATO, fast fire rate. Same round as the M16, M4, and many other standard military rifles now...then what about a SAW, or Squad Automatic Weapon? Any difference between capability or versatility between the two?
