And most people will never go to this extent when they "build" a car.
I sure as Hell won't!
And people wonder why the restomods and customs get 100k or more at Barrett-Jackson. They don't realize the man hours spent doing things no one will ever see. And most people will never go to this extent when they "build" a car.
Great job once again Donovan.
Question for you Donovan. What is the reason you will dress the welds? I'm sure your welding will look great and being in an area no one will ever see. Is it just your wanting to do it or does it accomplish something more structural?
And by dressing the welds i assume you mean grind smooth
Nice work D but I have a question that has always ate at me in my chosen profession and yours. I'm sure it's crossed your mind several times but what's the plan for what's now inside? Cavity wax? E-coat? Or prayer perhaps?
I'm sorry I just know that we are way! above the line of (rust belt) and I'd hate nice work to...... Turn
I only brought it up because it's a battle I'm always facing. I've used just about every method and form of auto body snake oil out there and I always feel like I didn't get enough of whatever in wherever. I'm not as careful or OCD on late model wrecks as on my own stuff. On them it's repair to manufacturer specs as per all Datta and block it out of my minded lol I've got questions for myself on things I'll be doing to my 87 soon but I'll probably decide on the fly.Thanks Shawn.
Yes it’s things like this that people don’t realize that sometimes have to be re-engineered to accommodate other changes that get made. All they see is the finished product and go “hey, that’s really cool” and don’t give it a second thought as to what went into it much beyond that.
There’s always a cause and effect to any modification that’s made, and usually the more extreme the modification, the more drastic the effect on factory parts.
Yes, by dressing I under mean grinding smooth Tony. To answer your question, it’s for nothing more than pure esthetics, plain and simple. It has nothing to do with anything structural, I just want it to look nice and like it might’ve come that way when it’s done.
Plus it’s good for my OCD.
No apologies needed Eric, it’s something I’ve been pondering myself. After further reflection today, I think the course of action is going to be weld and dress all the edges first, then mix up some epoxy primer and pour it in through the body mount hole. Turn it around and around to get it in all the corners and nooks and crannies, then pour the excess out. Run the body mount bolt into the threads before it sets up so it doesn’t clog up the threads, then set it aside to let it cure.
That way all the welding is done ahead of time, none of the epoxy gets burnt off and compromised, and all the bare metal areas will be protected. I considered your suggestion of using cavity wax, but my fear is that it won’t hold up very well long term.
Plus there’s no real way to guarantee 100% coverage inside with the applicator straw.
Thanks for bringing this up, it’s a genuine concern and something that I was already thinking about.
Bridging metal with a mig brings back horrible memories LoL good show of patience! You should get a metal for metal work lol looks awesome.Well, no Mike today, apparently he’d rather binge watch Ozark with his ol lady than come play with burning metal. No worries, I got after it late this morning and made shizz happen on my own anyways.
Started off by knocking out the rocker panel seam delete…
…then dove right in to fixing the ugly upper joint between the two panels. I had put a flange on the bottom edge of the quarter panel thinking that it would make it easier to locate the pass-through insert, and while it gave me something to Cleco to, it royally screwed with the straightness. It had flattened out the area, and to make matters worse, the top half of the insert was quite short and bent inwards at a bad angle.
So to correct this, I cut the upper tack welds and the flange completely out.
This left a sizeable gap between the two panels unfortunately:
I broke out the UniSpotter and the slide hammer with a large flat 90 degree hook on the end, and started straightening things out.
Once I got things aligned properly, I then began to weld the gap up. DISCLAIMER:
I definitely DO NOT recommend doing this the way I did, usually trying to weld up a gap this large between two panels of the same gauge will result in it pulling inwards and leaving a nasty valley between the two.
However.
I had a couple of things working in my favour, the insert is much heavier gauge steel than the quarter, and the proximity of the upper edge to the welded pipe meant that the area was very strong and wouldn’t move a whole lot.
So I started doing what I call “bridge tacks” (because they bridge the gap), and continued doing so until I had only a 1/4” or so between them. Once that was done, I knocked the tops of all the tacks down almost flush and started welding in the gaps working from the center out.
Again, definitely not usually recommended unless you know what you’re doing. Weld, cool, grind, repeat. Weld, cool, grind, repeat. Over and over, probably in the neighborhood of 40 or 50 times. After a couple hours sitting cross legged on the floor repeating this process over and over, I finally had it fully welded.
It had still pulled in a bit (I had anticipated that), so I stitched on another row of porcupine quills in the valley and pulled it out with the slide hammer. A little dressing with 40 grit on the big wheel 8” grinder, and voilà. One side completely done!
I think it looks killer, and that’s even without the trim bezel or the exhaust pipe back in there yet. This has been a long time coming, and I’m so glad to see it all coming together.
It was another good day.
D.
