Sooooo, the aftermarket strikes again.
Ya gotta love it when shjt pops up unexpectedly and derails your planned progress for the better part of three weeks.
When I had the driver’s seat installed for the ergonomics locating of the E-brake handle, I wanted to reinstall the passenger’s seat as well, well, just because. Good thing I did too, because…
When I’m working on the car, I tend to stop periodically and take small breaks to size things up and plan my next moves. It was during one of these small breaks when I happened to look through the back window of the car at the seats and how they looked in there.
With the small LED light I have temporarily zip tied to the inside of the roof, it provides the perfect level reference for things inside the car. Looking at the seat backs through the back window, the passenger side seat looked absolutely perfect. Nice and straight, headrest perfectly level with the light. The driver’s side however, WTF??
It looked like it was all gangsta leaned out towards the center of the car, like a 300,000 mile hooptie.
Simply unacceptable, especially with the build level I’m striving for.
So, out came the seats, and off came the seat base brackets to figure out WTF was going on. I bolted just the seat base brackets in by themselves, and started taking some measurements with the digital angle gauge. Even though the car isn’t straight and level on the jack stands, I knew I could use the passenger side bracket as a datum point because it looked perfect in there. I zeroed out the gauge on the passenger’s bracket, and wrote the numbers directly on the bracket for comparison to the other side. Unfortunately I forgot to take a picture of this as I was still in investigation mode.
The numbers were however:
Front crossbar side to side: 0 degrees
Rear crossbar side to side: 1.1 degrees. (A bit much, but ok whatever.
Inside crossbar front to back: 3.4 degrees
Outer crossbar front to back: 2.6 degrees
I averaged out the front to back measurements to 3 degrees, about what I figure they should be.
Taking these measurements, I repeated the measurements on the driver’s side bracket, and holy f**k, I did not like what I found!
Back crossbar:
Front crossbar:
Yep, you’re seeing that right, a 4.6 degree angle inwards across only a foot wide span! No wonder the thing looked gangsta leaned out.
So, what does a 4 1/2 degree difference in angle look like in height compensation? Here I stacked a couple of spacers underneath the level, and it STILL wasn’t enough!!
Now to be fair, I know I had modified this seat base a little already, but there’s no damn way in hell I introduced a 4 1/2 degree difference in angle with what I did. This could only have come from the manufacturer that way.
Now I couldn’t exactly just modify the inside feet and add that much material without throwing everything else out of whack, so I actually had to cut all 4 feet off the base and start from scratch. I made sure the outer feet were the same height as the passenger’s side, then went about making everything else correct to match using the angle gauge.
Here’s the corrected base tack welded back together using spacers, scabs and anything else I could find:
Even with cutting all four feet off and starting over, the inside feet were the ones that needed the most modification and height added to them. Here’s a look at the front and rear inside feet from inside the bracket and how much height has to be added to them:
Pretty significant.
So after a couple weeks of sporadic work on it, I finally got it all fixed up and put back together. Had to cut several new pieces out of some 3/16” plate I had stashed away in my metal scraps, including a completely new gusset for the front inside foot.
Where did we end up at the end of it all? Not perfect as when it was tacked together due to some distortion from the welding heat, but only out by a couple points of a degree which will never be noticed anyways. I can live with that.
And how about the seats once they were reinstalled? The passenger side as noted is still perfect…
…while the driver’s side looks much better, but maybe not quite perfect.
I discovered that this is actually somewhat of an optical illusion though, and the numbers don’t lie to back it up.
I put the angle gauge on the driver’s seat in a couple of different locations, and they all confirm the same.
Top of the seat underneath the headrest:
On top of the headrest:
On the front of the seat bottom:
And across the seat bolsters:
Again, out by only a couple points of a degree, nothing that will ever be noticed or felt. Also to be taken with a grain of salt as soft upholstery isn’t the greatest for getting accurate readings from.
After all that cluster f**k to make things right, I took the opportunity to get a couple of pictures of both seats reinstalled and sitting properly. I figured they owed me that at least.
Frigging aftermarket parts, I wish it was possible to buy something that fits and works the way it’s supposed to the first time.
So now that that unexpected 3 week sidetrack is in the books, maybe now I can finally get back to modifying the tailpipes where they go through the pass-throughs, and come up with some brilliant plan to support the rear of the exhaust system.
Then back onto finishing off the floor.
D.
