Is the foam closed cell, so no worries about holding moisture? Not that it will see much anyways….
Oh man. Your attention to detail about stuff i didn't even know about. Questions will be asked in the future especially about the foam stuff. But for now just waiting patiently for more.
Donovan, I think you have the patience of Job. More excellent work. Like you, I am looking forward to seeing the finished product. I also have questions about the foam stuff, but will wait. Are you also going to paint the floor? I know it will get carpet, but I'm assuming that you'll seal it up first.
You did answer my questions. But being that this particular 3M product expands 10 to 1, is there any chance it can actually distort an outer panel? And bringing up spray foam in a can there are many different types. Yes the 3M you used is closed cell as I already did the research. Reason I wonder about that much expansion is some spray foam can bow a window or door frame causing issues. So they make a less aggressive foam for that task. I really like the idea of filling the voids and helping with soundNo worries, ask away when ready, but your questions just might get answered here and now as it would seem some of the other guys are curious too.
Thank you again Jeff, as always I appreciate the kind words. “Paint” may not be the correct term for it, but yes it will most definitely receive a coating. I will eventually be spraying the entire floor pans, front to rear, in the same epoxy primer that I’ll be shooting in the next couple days. Epoxy primer is pretty much the most effective defense against corrosion, is tough as nails, and is compatible over top of most any substrate. A much better alternative than straight paint for this purpose.
The topside of the floors will get sprayed in epoxy, then get DynaMat or similar product, then underlay and eventually carpet over top. The underside will get coated in epoxy first, then likely Raptor Liner or some other similar truck bed style coating. I may or may not paint the liner coating afterwards. Truck bed liner coating may not be the prettiest, but it’s hard to beat for durability. I’m just holding off on that until the body goes on the rotisserie and I can easily address the underside before I tackle spraying the floors.
As for the foam, I’ve got no stake in this game so I’ll tell it like it is from my experience with it.
To answer @superbon54’s question, I do believe it is closed cell. That is, I seem to recall reading somewhere in one of the tech sheets that it is closed cell, at least in its cured and untouched form. I say untouched, because when I trimmed off the excess, it appeared to have the consistency of an Aero candy bar inside. I think I likely compromised the integrity of the “closed cell” portion of it as soon as I cut into it.
In all honesty, I don’t think I would buy this particular product again. Go to your local hardware store and pick up a $15 can of the regular expanding foam stuff, because that’s exactly what this stuff appears to be. Minus the $100+ price tag just because it says “3M” on it. I honestly can’t differentiate anything different between the two. The only advantage I can see to the 3M stuff is that it can be used as many times as needed until empty because the dispensing tips can be changed when the product hardens. Where as the hardware stuff is a one and done, wasting the unused product once you’re done with the initial use.
This was one of two foams offered by 3M, it’s marketed as a rigid foam for filling large gaps and voids such as inside B and C pillars. It dries hard as the description implies.
The other foam I came across in my research was a soft flexible foam, designed to reduce “flutter” between panels. Think like the glue “dots” that separate the hood skin from the underlying structure on our cars. To the best of my knowledge, neither one will hold moisture. At least it’s not mentioned in the technical descriptions.
Haha, I was wondering as I initially was reading if the hardware store stuff could work. Those 3M labels and fancy packaging are expensive! Great write up on the stuff, and stellar work on the ride! I get the need/want for dynamat and carpet, but damn it seems like you’re putting a curtain in front of the Mona Lisa🤣No worries, ask away when ready, but your questions just might get answered here and now as it would seem some of the other guys are curious too.
I’d like a live feed please.
