Honestly Ive nothing but problems with it. The geometry is not correct and Bernie doesn't want to admit it. All of my parts are bone stock, GM replacement parts. So it's not a Chinese part quality issue. I didn't have enough throw to even bleed it in the first place. He emailed a template so I could drill and tap a new hole, lower on the pedal. I did that and that's how it's been since. I STILL don't have enough throw. I'm literally 95% of the way there. I have to bury my foot into the pedal and the clutch just barely drags. There is more throw on the clutch master, just the pivot is incorrect. I cannot simply drill another hole further down for multiple reasons. The pushrod is at max angle into the mastercylinder. Second off. My clutch pedal is already 2" higher than my brake pedal. If he would just admit there is an issue I'd be much happier. But selling them as a "bolt in" solution is a straight up lie. I could use a larger master cylinder, but the master will hit on the upper control arm.
What I'll have to do is remove the bracket, cut it on the side where it's welded, take it to work and add a few degrees of bend to the portion where the master mounts, so the pushrod will be at the correct angle. Reweld, install, then drill ANOTHER hole in the pedal further down to get full movement of the factory GM master cylinder.
Let me guess: he's sold a million and you're the first to complain.
