Tony, they’re definitely a much more aerodynamic style than the originals that the car came equipped with. I figured they would suit the car if we were able to get the mounting angles and placement figured out. So far I’m not disappointed.
Thanks Jack. You’re 100% right on the F body cars, I just wasn’t aware until later this morning that they came optionally equipped with the power versions. I’ve never owned an F body.
As far as the mirror to door gaskets are concerned, if the integral pedestals were just a touch taller or if I didn’t have the wide belt mouldings on this car, I would’ve been fine. But because of both factors, I’m going to have to figure out how to do some smidge taller gaskets. Like less than an 1/8” to provide clearance to the mouldings, it’s that close.
Thank you!
Thanks for weighing in, I was hoping you would. Once I learned that the Camaros and Firebirds had powered mirrors as an option, I started researching them and looking around on eBay. From what I’ve read, the power and manual cable versions both utilize the same internal mounting points, so therefore they should be interchangeable. As far as the switch is concerned,
UC645 sent me a whale bodied
Caprice joystick style switch a while back, so I already have that to use.
As of this writing, and after this morning’s post, I’ve since pulled the trigger on the power F body mirrors I found on eBay:
So now this way I should have everything I need. Two more housings, glass, mounting studs and nuts, and gaskets for spares. Plus the motors, wiring, and pigtails to adapt to the
Caprice switch, I’ll just have to figure out the function of each wire on each mirror plus the same with the switch.
They should be here sometime in the first week of January.
