Hey everybody, thanks for the replies and feedback.
My apologies for being so late to respond, it's been a busy weekend, but well worth it...
Yesterday I spent the morning chasing down a G body "unicorn", but more on that a bit later.
Hey Donovan, just catching up on the current updates. For what its worth I vote for the stock lynch pins. I think they follow along with the theme of the car better in regard to the other fasteners you have used in your build. With everything having a polished and finished look to it, i think it would look out of place with the cheaper looking pins. As always, my compliments to you on the re-work of the hood. Without the templates in place, one wouldnt really "see" the inconsistency that the templates pointed out. Its amazing what a few pieces of cardboard can reveal when it comes to metal fabrication. So keep on keeping on with the juggernaut, you have quite a few eager gear heads waiting for the final reveal!
Kevin
Kevin, thanks very much for your input, it's much appreciated, and good to hear from you again!
You're absolutely right, something can look fine from outward appearances, but sometimes it's not until you compare it to a template that you realize all is not as it should be. And that's exactly what I found in this instance. While it was a whole pile of effort to fix, I'm just glad I found it at this stage in the build, and not after laying down filler and trying to block everything straight...!!
I vote lynch pin as well. The other pin puts the ring off to the side (I like the round over round the lynch pin provides) I also think the offset ring has a chance to flop over into the painted area and eventually wear a mark in the paint.
BUT.......It is your car, and so far you have been amazing me with what you're doing, so keep it up.
Hutch
Hutch, thanks very much for weighing in with your thoughts as well.
Your response was really the single one that really got my gears turning on this issue.
You brought up a great point about the rings possibly flopping over and scratching the paint, but you also made me realize that there is a high risk factor that those pins could actually work their way quite a ways out before they hit the spring loaded balls and have the pins dig into the paint badly that way as well. Not acceptable at ALL.
Thanks for that. Sometimes that's all that's needed, is a different perspective on an issue. And you gave me just that!
Donovan
