The Purple Monkey Dishwasher TBSS
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
On the way home from the body shop I couldn't get the AC to work. First thought was it finally lost its charge. While changing the wheels yesterday I found a clue.
That belt was brand new in December. So three months old, with minimal use. Second thought: cheap belt.
Reality check: compressor pulley is seized/grinding.
FML - I don't want to play this game anymore.
  • Sad
  • Wow
81cutlass
4,639
13,542
Western MN
Does a TBSS have the G3 LS style AC belt where it has an idler or does it have the G4 stretchy belt?
It might just be the tensioner pulley?
motorheadmike
8,976
27,522
Idler style. Original at 144k miles.
But, I got my hand on the compressor pulley and it feels like seized/seizing bearings. It's bad. It wasn't like that in December - I checked.
81cutlass
4,639
13,542
Western MN
It's a pain but doable. I've done my compressor twice.
Pull radiator, some rad hoses/coolant hoses, coolant & washer reservoir, kinda wiggles out the front.
  • Wow
CopperNick
3,347
3,011
Canada
The joy you feel when you remove the dying compressor will only be compounded when you take a bat or a crowbar to the soon to be a recyclable corpse and pound it into a pulp, thus speeding it on its way to the scrap bin. Do not forget to remove all the little fiddley bits that you might need for when you install the new one.
motorheadmike
8,976
27,522
It's got a power steering fluid leak at the cooler now too. F me sideways. Bypass it?
Winter use only I suppose.
  • Wow
  • Sad
Tomeal
913
1,619
Clyde,pa
Look at how far apart the kitty is. If you don't fix it right you will second guess or regret yourself. You don't need it right now, budget the time fix it the way you know you want to!
CopperNick
3,347
3,011
Canada
Is, strictly speaking , the cooler necessary? if not then pull the lines and cork or plug the ports with appropriate fittings. Once you score another cooler or yard the bleeder out to get it resoldered, then you can re-attach the lines and back to rock and roll.
motorheadmike
8,976
27,522
They installed it from the factory... and I put oversized tires on it. So I would say it's needed.
Ironically a larger universal unit is cheaper than the OEM replacement. Guess I know what I'm doing, eh?
