Thoughts/Preference on SBC Aluminum Heads
57 Handyman
339
389
I'm building a street 350 motor for my 87 El Camino. Currently, I am in the market for a set of heads for my motor. I read on another site that Summit Racing heads are built by Trick Flow, specifically SUM-162109. Any confirmation on this?
Motor consists of forged, balanced crankshaft, rods, and flat top pistons with 2 eyebrows; Comp Thumpr Cam 12-601 with matched springs, push rods, hydraulic lifters, and self-aligning 1.52 ratio roller tip rockers. As an old school guy, I plan to run a dual quad setup consisting of '57-62 Corvette WCFBs on a stock intake manifold.
Thanks in advance.
  • Wow
1320John$$$
951
2,043
Pennsylvania
The 180 Brodix IK will keep you smiling they work well on my uncles 327 Powered Corvette four-speed 308 gears if you’re just looking for an aluminum head look go with the Chinese stuff
39F
530
602
Pittsburgh PA
Trick flow has them double humps now pretty cool idea , summit also has there own version ,just food for thought to keep it kinda original ish lol
  • Informative
1320John$$$
951
2,043
Pennsylvania
That’s right trick flow did come out with the knock off double hump anybody see flown numbers on these things yet
565bbchevy
9,614
12,683
Michigan
39F
530
602
Pittsburgh PA
Yeah at what mercury drop and what size bore did they flow it on AFR tells you what size bore they are using small blocks are 4.100 flowed
Not to sure on that it was on a article , probably just the advertisement flow , definitely alot more plays into things. Look at the price tag between tickflow and AFR tho lol
1320John$$$
951
2,043
Pennsylvania
Brodix makes a nice head for the money
