tight clutch pedal
cny78
32
How odd is it to have zero free play with the clutch pedal as high as possible after rebuild with new pressure plate, disc, and t/o bearing? It's a 4-speed Saginaw. Barely got the adjuster rod between z-bar and bearing release arm in place.
9,154
15,318
Do you have the right throw out bearing matched to the pressure plate fingers? It sounds like you might have a long throw out bearing with long pressure plate fingers. Another issue could be a incorrect lower rod if you replaced that too.
cny78
32
Did not know there were 2 sizes bearings. It's a Perfection Clutch kit stock replacement for my 78 malibu, 400 sbc, 11 " disc. Do not want to deal with pulling that trans out to measure the bearing. Will try to find out which bearing I have. Your reply does make sense, thanks. I replaced the entire linkage system; matching it with the what was in the car. Nothing different. Do you know why there are 2 different bearings used?
buick7332
350
589
N.E. Philadelphia area
The clutch fork is also gbody specific
Just take the lower rod off, and see if you can wiggle the fork and throw out bearing. If it doesn't move at all, you probably have the long bearing. You should be able to see something in the...... wait for it..... fork hole!
9,154
15,318
The bearing lenth is related to the fingers of the plate but if it is a match set then it should be OK. Now since you said you're running a 11" clutch, what bellhousing are you using? the 11" housing is hard to find & a one year only ('78) item generally used with El Caminos & Caballeros with 350's. That bellhousing will be p/n 464697 & will have the offset ball stud like the 462606 (SBC 10.4") & the 563441 (BOP 10.4"). As buick7332 stated the forks are specific to our cars for these bellhousings, no other platform used them. They are curved to match the offset of the ball stud.
cny78
32
My bell housing has #3899621 stamped. The engine is a '76 400. The fork does not appear curved and does not align well with fork. Everything worked when I drove it home though. I can barely wiggle the fork with the rod disconnected, it does move.
10,563
14,292
The clutch fork ball stud was also available in three different sizes. It is critical to the fork placement. There is also an adjustable stud.
img_0955-jpg.103801
cny78
32
img_0955-jpg.103801
Bonnewagon- great photos.. I never removed ball stud from bell housing when cleaning up. Like I said, all worked when driven prior to rebuild. Do you know if the stock t/o bearing is 1 1/4 in tall? I am waiting to contact Perfection Clutch to find out size they have in my kit.
gnvair
1,106
1,305
You need to check your pressure plate. There are flat finger diaphragms that use the long throw out bearing and the bent finger diaphragms that use the short bearing.
Also, from my own experiences
A standard bell housing such as that 621 housing and a standard fork will cause the fork to contact the floor right under the gas pedal. Did some one bash the floor in there?
