Timing chain advance/retard?
A buddy once put a cam in upside down on a corvette
350hp350 it was long cranking, hard start , but it ran … not well but enough that his dad laughed and said tear it down you put the cam in upside down lol
Reactions: g0thiac
I had a similar situation many moons go. I tried everything under the Sun to get it to start to no avail. Eventually I opened it up and found I totally screwed up the timing marks on the gears. Sometimes the gears are a tight fit and struggling to get them on results in getting them out of position. One tooth off will cause it to run like a steam engine. More than one and it won't run at all. The hardest part is convincing yourself to open up a freshly sealed and painted engine. Setting up a degree wheel is probably above this guy's pay grade and I refuse to get involved any deeper until his attitude changes.
180° off solved by rotating the distributor firing order 180°? I did that one too.
Bingo!!! How they got the gear on backwards first, and then found a mark on a tooth to line up is amazing. This engine actually started and ran but would not accelerate.
I still don't see it but I rarely do Chevy stuff.
That flat surface around the bolts is the thrust face that rides against the block. The 4 grooves allow oil between the block face and the gear. Usually standard 5/16” bolts with 1/2” bolt heads are used. They had to use Allen head bolt To clear the thrust surface
