We all know this too well somebody is going to learn a lesson the hard way
Take the time to pull the body off your thank us later
Whatever gets you to sleep at night..... I usually keep my expectations low to avoid disappointment.the rest of the frame is fine it’s literally just that mount that rotted away on me
That’s to be expected of a Oldsmobile ownerWhatever gets you to sleep at night..... I usually keep my expectations low to avoid disappointment.
Thanks for the advice and input I’m fully prepared to have taken the body off if I had to.. the rest of the frame is fine it’s literally just that mount that rotted away on me ... I will post some more pics when I get the new piece welded in
G bodies don't have very thick metal new, blasting or encapsulating rust, to late the damage is done.it Looks worse in the picture the rest of the frame is solid I’m from Canada and the car was driven in winter prior to me buying it and starting to fix it up all the lines are going to be replaced I’m just loooking for some advise
