Do you think I can patch something in there with out pulling the body of the car offI would cut that section off and fabricate a replacement piece and weld that on.
I think it could be done in car but it would be easiest if you have access to a hoist for room to weld and line of sight if not you could get creative and make a 2 piece replacement and have one weld at the top inside that you would weld from under the car and then the bottom piece that would be welded to the frame on the bottom where the factory was and another weld to join the two pieces together on the inside facing the driveshaft.Do you think I can patch something in there with out pulling the body of the car off
