**A good chunk pf the 80s SSs had 7.625 rear ends with 3.73s and 28 spline axles. Posi was optional. Normal Montes might have had the 7.5 with 3.08 and down.
The 80s SSs have always had 7.625 rear ends with 3.73s and 28 spline axles. Posi was optional. Normal Montes might have had the 7.5 with 3.08 and down.
My 88 SS Monte has the 7.625 and 26 spline axles. The ring gear is just .125 larger in diameter.
I was told by a past employee at Chevy Delavan (Axle plant in Buffalo) the 28 spline axles started in late 1988 when the G body was already out of production.
So my question is, can you get 28 spline axles for the g body's ?????
I bet those are hard to find also? Is that the 8.5 g body rear end only or will the earlier camaros work also?Yes. Stock axle for the 8.5. Will slip right in the 28 spline 7.625 carrier.
