That's really cool! A blow through setup sounds like a pretty tricky project, but I'm definitely not a carb guy myself so I know very little about them Sounds like a really cool project though!You are my new idle. I have a Turbo Monte. I gathered all the parts and engines to put a Series Two in my car, but I put it on hold years ago and built my original 3.8 into a intercooled blow through engine. I can say I am happy with the choice. That car runs really good. Two years ago I bought a 2003 GS. I have a stage one kit on that car. Tuned ECM and a 3.5 pulley. It runs pretty good too. I recently bought a 81 Buick Century. The plan is to put a Series Two in that car and later the Supercharged engine out of the GS in that car. The GS still has a lot of life left in it though, so it will be a while. I have been daily driving the Century because it gets good mileage and is comfortable to drive, but I can't wait. I think you have an awesome combination. I don't know why more people don't go that route. Probably because it is not all laid out for them? Love your car and what you have done to it.
3.5" pulley is pretty stout, If you're interested in trying Ethanol it's a really good car to do it for. My 02 GS is all stock but with 60# injectors and runs on E85 but it feels way faster than my 99 Regal did with headers and a 3.4" pulley, and it's so much more consistent. It's frickin magical
The century sounds like a really cool swap too!
I definitely am surprised there's not more 3800 swaps in longitudinal RWD cars. These engines are really reliable, really easy to tune, they're cheap, and can make gobs of power when you turbocharge it even on the stock bottom end. I don't know if anyone has actually found the limit of the stock rods and crank yet.
There are a couple reasons I can think of as to why it's not in more RWD cars though:
- To even put it in the car you need to be able to weld motor mounts and modify the exhaust for most cars.
- There's basically 0 parts you can buy for these things off the shelf to make the swap easier for a longitudinal car.
- Turbocharging or supercharging one seems like a really difficult task. The M90 faces the firewall and needs to be welded to turn it around, or you need to get a different case or just a totally different supercharger. A turbo needs exhaust manifolds to be built or modified to make it work. Takes a lot of time and to get things right and most projects seem to be abandoned before they're running.
- Transmission options are a real grey area for these things. A lot of people who are into 3800's don't even know these things came RWD with a stick or auto trans. Even a lot of people who are planning to go RWD will create threads asking about what transmissions are out there.
- The stock 4l60e is a real enigma for these cars. It shares some components with the V8 4l60e, but the input shaft and pump are different and apparently the lengths are different too. This makes it so you have to play detective when you rebuild the trans or reassemble it to figure out what parts are V6 specific and intended to be there or what aftermarket parts you can or can't use. The V6 version is weaker than the V8 version but it can actually handle a decent amount of power from what I've seen so far, I'm sure it would do way better with a good rebuild though.
- There is an adapter you can buy for these things to bolt them up to a 350/400 trans, but again most people aren't aware that it exists
- The T5 trans these came with for the RWD manual Camaro can't hang at all and good transmission swaps will run thousands of dollars. Most manual trans swaps are not documented at all and even people who know almost everything about these cars don't know how to put a good stick behind them or haven't ventured into that area.
- Not a lot of documented details about these in the 3800 world or other people who've really gotten into them in a RWD setup. For sure those cars are out there and I've heard of a few but I can never find a lot of details about what they've done with them or how they've done it.
- Stock PCM is starting to show it's age with what it can do compared to some of the LS PCMs out there.
There are some people out there though that are really serious about the 3800 and will throw thousands of dollars into the 4t65e trans for parts that don't even exist anymore so who knows. The problem with most 3800 builds is that they have a 4t65e bolted to them and are limited to whatever power that thing can hold. I'd argue very few people have properly tested these engines because of that.
If I can inspire people to instead direct their effort into something more rewarding like putting a proper transmission behind these things or if I can bring more exposure to what you can do with these engines then I've accomplished my goal haha!
I can hear people already writing comments about LS Swaps right now. Obviously there's nothing wrong with an LS swap, of course it's an amazing engine but I'm honestly just tired of seeing them everywhere I go myself. I wanted to have something different that still can keep up or outrun them to show that there's more things out there you can try.
