For the longest time I thought the Terminator only worked on LS engines too or other V8s until I started looking at the software. It really is just a cheaper version of the HP EFI though and it was pretty easy to set up for the most part!
Basically just tell it that it's a 231 cubic inch 6 cylinder
Then it needs a custom ignition configuration to use the 3800's 3x sensor since Holley doesn't support an 18x signal on the crank.
I'm really excited for this though! It's going to make power tour much less stressful because I have a flex fuel sensor in here to automatically adjust fueling, boost, and timing based on the ethanol content. I can also ditch my other modules you typically have to run a higher end 3800: MAF scaler, boost controller, WOT Box, other data logging methods, the MAF itself 😆
There is a way of converting the 3800 to use LS style coils but I'm having trouble finding the link where there's someone selling the module to make it work..
