CUTLASS Turbo LS Cutlass, almost road ready
But....but...."g-body LS swaps aren't cheap" and "a stock 5.3 swap costs $14k". Pretty cool to see you disprove conventional wisdom.
I am collecting parts for a similar build with a similar budget.
Hell yeah man, I'm all about budget builds!
This is the 5th build I've done, and the first two went way over budget and out of control. The next two I shot way lower and was able to stay inside a budget and had just as much fun with the cheap parts as I did with the expensive parts.
This time I had a goal in mind: Run 10s for $5k.
At first I started gathering SBC parts, but then found out about our lord and savior, TURBO LS.
So I sold/gave away all that junk and went to the local pull yard. Grabbed a 5.3 and put together a build list. Put the engine together, covered it and pushed it into a corner of the garage. Took me two years to find a chassis that fit my budget and requirements. It had basically boiled down to three options; Fox Body, F Body, or G Body. But I found this G body, and man am I glad I found it. Over the next two and a half years or so I got the engine installed, turbo kit built, engine harness made, rear end rebuilt w/ new gears, and transmission built. Ended up having to shorten the driveshaft 2 3/4 inches.
As it sits I am barely over $5k. I still need to get grippy tires, and its time to head to the track.
Nice.
What is the motor? Stock? What turbo and cam? Where are you in PA are you? First MS?
Sorry, I missed answering this.
Yes, this is my first experience with MS. Overall I'm happy with it. Personally I prefer it to the AEM Infinity standalones I've messed with.
Reactions: Tony1968
That's a lofty, but attainable goal. I think you'll be another $1500 at least, but I'd love to see you prove me wrong. I'm in a similar boat with a goal, only a little faster and a little more money. I'm trying to stay under $10K. My biggest hurdle has been having to spend more than once for the same part, namely trans and injectors.
I believe the real fun is in trying, and the living and learning along the way. You're never going to be the fastest because there is always someone else doing just what you're doing and learning from your efforts. But you're gonna do sh*t if you don't try. Might as well have fun along the way.
Good luck and stay safe brother - Jim.
Hell yeah my man! I like your style.
Reactions: 64nailhead
A 5.3 with a GT45 is a handful on street tires.
Get some sticky tires on there.
Don't worry about that AFR reading, I don't have the wideband parameters setup quite right yet, its not reading exactly right in the software.
IDK why this one uploaded in potato mode
I got the brake fluid flushed and replaced with DOT 4 . It's nice having brakes.
I need to order tires, once they're on then its going to get inspected.
Reactions: Tony1968
Sounds great. Are you using an IAC or no?
Reactions: Tony1968
