Turn Signal Arm
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I wish. My TTA needed about 50 lb/ft of torque to loosen when I was tightening the column bolts and that is hard to do without marring the soft metal.
maybe the owner before you had the same problem I had and used locktite permanent sealer to install it...
airboatgreg
2,869
3,115
It pulls out. Spray some cleaner/lube in there. Push in an out and work gently several times. Do not get in hurry. Pray to G-Body Gods.
Last last resort... mutter under breath and yank it so you just have to fix it.
