Yeah they have power to them.have you checked the sockets with a circuit tester?
It dose work but with the lights on the front side marker light/turn signal goes outdid you check them using the ground in the socket?.....what about when you have the turn signal on
the bulbs are #194 and yeah I used the bulbs from the rear to the front still does the same resultswhat bulbs did you use and have you tried using the bulbs from the back in the front
Yupare you talking about the side markers?
Ok cool I'm thinking it might be the turn signal switch what do you think?Front and Rear are both bulb #194.... but just for the hell of it, instead of front to back, switch side to side and see if the problem changes to that side. If not, and based on your earlier description of the dash light and hazards occurring as part of the issue, I'd say it's either a problem at the terminal or the wiring itself. I may have a wiring diagram somewhere around here...
