Turn Signal Problems
It looks like that yellow cylinder bonnewagon posted a picture of, it'll probably be aluminum/silver in color. If you can manually blink them moving your lever to off/left/off/left/off/left or same with right thats just a flasher.
Bonnewagon said:
This is it, along with the clip that holds it. Usually right up under the dash, to the right of the steering column.
mine is located in the fuse box....
Well group the problem was indeed the Turn Signal Flasher! it was a b*tch to get to but once i did i was able to swap it out with a new, louder model from autozone
After that all my signal worked perfectly, now i just need to maybe replace the bulbs in my dash because only one of my "on dash signals work (not to concerned about that since im flashing again)
Does anyone knw what this fuse/relay does?
Is that the one next to the plastic speaker chime box?
Family, That looks like the horn relay to me, could be wrong. But I know it has three terminals like that one. Without that you aint gonna honk.lol
perfect perfect perfect. wow, you guys are great! lots of useful information. i actually had the same happen to me yesterday. i thought it was the same as the one on the fuse box, but apparently not. now ill look for it tomorrow during the day. thanks.
I'm having this problem with my 83 Hurst Olds, thanks for the post.
Where about is this under the dash?
