turning key to start but nothing
lower your steering column, and look at your ignition switch. looking at the terminals the left bottom (facing the diver side door) is your wire that goes to the starter solenoid should be a purple wire unless someone has changed it. the red wires that are split in two usually are your fusible links. they are connected to the battery terminal on your starter.
