it's pretty simple, disconnect the battery cable and you put a jumper from the battery terminal to the S terminal on the solenoid on your starter. If the batter cable you have is long enough we just cut it and put ends on it to use with the solenoid The purple wire and the two red wires with fusible links need to be extended so we need 10 gauge for the red and 14 for the purple wire.
