so this is gonna be a dumb question but i have a 1981 Monte Carlo(4 4x6's). I do not have the factory gauges or lights anymore, so i dont have an indicator as to when my high beams are on. Also purchased the car as such with 2 burned out sealed beams.
What is the factory light output/behavior on low beam and on high beam?
I have h4 hella housings on my outer most lights and moved the old sealed beams (3 prong) to the inner position. When the h4's are on high beam the sealed beam inners appear to be on low beam then the opposite when the h4s are on low beam. To run 4 on high do i need to switch which pins im using on the inner sealed beams? since the inner harness only has 2 prongs?
