Completed the Hella e code install. A few observations.
- much better road lighting while keeping OEM look
- p.i.t.a. to install headlights in a SS
- without the harness adapters high beams are on dimly...must use supplied harness extension
- the heat radiating from the front of lit lights is really handy for warming up cold fingers
- I have not yet made and installed a relay light switched circuit - undecided at this time.
FYI....Kirban Performance offers a great hd headlight wiring harness with dual relays that works great!
It's a direct plug N play installation. Should be a good fix to ensure you are protecting your switches and ensures proper and full voltage to your headlights
Here's a link:
http://www.kirbanperformance.com/product/44103/H4+Headlights+Upgraded+Plug-and-Play+HARNESS+#7531.html
For your Buick, Regal Grand National, 3.8 1987
$67.95
Product Description
1981-1987 Buick Regal (All Models) -
1981-1988 GM - ALL A-Body and G-Body Models -
UPGRADED H4 55/60 HEADLIGHTS (4) KIT, HARNESS & HEADLIGHT
This kit will fit every GM car that takes this same size four headlight system, including all 1981-1988 GM A-Body and G-Body models.
NOTE - Kit #7530 and Harness #7531 will not work with HID headlights.
We have examined several of the various H4 headlight systems available and have found one that closely resembles the original style headlight. The headlight is glass and looks very close to the original glass face of your sealed beam headlight. To eliminate possible problems with the factory headlight switch and its ability to handle higher wattage bulbs, we also include a special plug-in harness. This plug-in harness takes the current directly from the battery after you turn on the headlights. The headlight switch is merely used to turn them on. This eliminates any possible problems with the 25-year-old headlight switch.
The stock sealed beam headlights are 45/55 watts. These new H4 formatted headlights already have a 55/60 watt bulbs installed. The plug-in harness that comes with this kit has two 80 amp relays and an in-line fuse to prevent any overloads.
The custom-made plug-in harness is highly recommended in the G-Body cars to eliminate any possible issues with the original headlight switch. Issues with higher wattage bulbs can cause the headlights to flicker or turn off completely.
This plug-in harness also allows you to upgrade to even higher wattage halogen bulbs (maximum 80 watts), if you want. It has been tested by our source running four 100 watt bulbs for over one hour with no problems. The plug-in harness is designed to be virtually undetectable under the hood.
Just upgrading to the 55/60 watt H4 setup will be an improvement on overall lighting, compared to what now is the antique sealed beam format. Once you get this H4 upgrade, you can easily upgrade to higher wattage bulbs, if desired.
Another upgrade that improves lighting while keeping your car stock appearing.
NOTE - We offer the set of four, or individually if you wish to purchase an extra H4 headlight the 55/60 watt H4 bulb as a spare (Part #7532.)
NOTE - We offer the Upgraded Plug-and-Play Harness (Part #7531) if you want to install a headlight kit from another source. This harness will work with all upgraded systems.
Another great upgrade to improve the brightness of the headlights, while retaining a stock appearance.
Here are the three options for these parts. We have highlighted in RED the one you are ordering if you order through this particular page.
7530 - 1981-1987 Buick Regal (All Models) -
Upgraded H4 Headlights (4) Kit - $129.95
Includes Four 55/60 H4 Bulbs and Plug-and-Play Harness
7531 - 1981-1987 Buick Regal (All Models) -
H4 Headlights Upgraded Plug-and-Play HARNESS - $61.95
7532 - 1981-1987 Buick Regal (All Models) -
SINGLE Upgraded H4 Headlight with 55/60 Bulb Installed - $22.95 each
Part # Applications Sale QTY
7531 Buick Regal Grand National 3.8 1982-1987 $67.95
