Upper Control Arm Bump Stops
tngbody
104
20
Looks correct as far as being on the proper side. Are those arms original or aftermarket? Just wondering. The slot opening may make a difference. Those rubber bumpers should be a pita somewhat to get them installed. If they go in rather easily, there could be treachery afoot.
Those are stock replacement arms. I have to use pliers to pull them thru the slot. And they are already lubricated with some type of oil to make installation easier. The only other thing is that I haven't tightened the control arm to frame bolts down yet where the shims go.
9,618
12,700
Can you post a picture of one installed on your control arm?
I used stock replacement control arms and that style bump stop for my Regal and they did not pull through easily
tngbody
104
20
I can install them when I jack up there control arm but when I let the jack down the bumper slides back towards the firewall and pops out.
