pontiacgp said:your right...I don't know what I was thinking but my excuse is I posted that just after I read this...NFL suspends Sean Payton for year
This Chevy 1.8 L, 110 CID engine is characterized by "Luv G180 Series 2-4. Late 75 check series for series 5 and up, 5 up will have tin valve cover.". This Chevy rebuilt engine block was originally manufactured by GM in 1973-1975. Our Chevy V4, 1.8 L, 110 CID Used Engine long block comes without the engine accessories and the tin parts. Remove the old engine accessories and tin parts such as exhaust manifold, oil pan and timing belt cover from the original Chevy block that you want to replace on your Chevy LUV car or truck. You may visit a certified Chevy mechanic or car repair technician to ensure a smooth installation. If you need a high performance Chevy 1.8 L motor, contact us for available Chevy LUV engine performance options.
Please call 1-800-378-7566 to buy a used engine
Product Name Engine Block
Applications 1973-1975 Chevy LUV
Performances High performance options available
Catalog No. HPX-135
Warranty 100,000 Mile / 7-Year
Engine Size 1.8 L, 110 CID
Engine Type V4
Fuel Type
Fuel Delivery
VIN Code "N"
Aspiration
Head Casting N/A
Block Casting 246,270
Crank Casting N/A
Shipping $175 (48 US States)
So the "timing belt cover" would lead us to believe it's also an OHC? I still need pics.pontiacgp said:Remove the old engine accessories and tin parts such as exhaust manifold, oil pan and timing belt cover from the original Chevy block that you want to replace on your Chevy LUV car or truck.
