Vapor casnister ?? Help
87gbodydanny
Apr 1, 2023
53
4
8
Las Vegas
Does anyone know if I can open these up and clean them ? Or I have to replace . Feels kinda heavy maybe half way full not sure. Thanks .
87 regal
ELCAM
1,124
1,270
Complements of member sIdwys.
Reactions: 4 users
69hurstolds
8,199
17,601
Typically, only the bottom filter is readily serviceable. Can't recall the part number off the top of my head. A478C or A487C comes to mind, but I could be wrong on that.
As described previously, the canister CAN be dismantled and rebuilt with pet shop activated charcoal bits, but not recommended unless you have some skills.
TIP: If you DO want to rebuild your canister, replace the foam "charcoal retainers" upper and lower when you get in there. The foam degenerates over time and even if it looks good, replace it. It's likely around 40+ years old and it's just time. Any similar open cell foam should work. Once it goes back together you'll probably not have to worry about it for the rest of your life.
  • Useful
87gbodydanny
Apr 1, 2023
53
4
8
Las Vegas
dammit sounds like a easy but headache job rebuilding . lol I think it’s better to just buy new one. anyone know of a good replacement? I seen some online have 3 port
Clone TIE Pilot
3,861
2,612
Galaxy far far away
Nobody makes replacement vapor cans for G bodies anymore. G bodies use a unique vapor can that lacks built in control valves.
69hurstolds
8,199
17,601
As well you know already it's GM p/n 17064622 if you need to search for a new one. Whatever you do, don't lose those mounting clips. They're unobtanium. The canisters are getting to be unobtanium as well.
17075824 and 17075849 are other numbers you can use for the canister as well. 2 port units, too, with no extra valves, etc.
If you have a 307, then 17085929 is the vapor control valve. Might as well replace it while you're at it. Diaphragms don't last forever on those things. Cheap insurance.
  • Useful
Reactions: 5 users
69hurstolds
8,199
17,601
The canisters would still all work, although the parts info callout says . The 3.8 uses a mirror image vapor canister control valve though from the V8 job due to placement and hose routing. Same function.
GM p/n 17085918. Apparently it's in the long hose going from the canister to the carb.
Here's one dirt cheap. Genuine GM ACDelco.
#40 on the drawing below.
