Remounting the canister can be problematic if you lose those mounting clips. They can be found under GM p/n 554665. Good luck finding them new, though.
Hold down bolts are GM p/n 12337838. Still available from GM. Or if you don't want to spring $6,000 per bolt from GM, you can opt for the Auveco 16828 aftermarket replacement. M6.3x1.81x20 with captured washer.
Hex Head Sems Tapping Screw M6.3-1.81 x 20mm
www.auveco.com
