I'm not trying to be a smart-*ss. Punctuation is helpful. If you put a little effort into making your post easier to read and understand you will have better luck with getting responses. From the following link....
https://en.wikipedia.org/wiki/Chevrolet_big-block_engine#Generation_V
Generation V[edit]
General Motors changed from using the "Mark" designation to the "Generation" designation because
Ford Motor Company owns the "Mark" naming rights as it was used on some
Lincoln automobile models.[
citation needed]
For 1991
General Motors made significant changes to the Big-Block resulting in the Generation V. The block received a one-piece rear seal and all blocks received 4-bolt mains. Additionally the main oil galley was moved from near the oil pan to near the camshaft. Also the
valvetrain became non-adjustable and the provisions for a mechanical fuel pump were eliminated. Cast aluminum rocker covers were fitted in place of stamped steel covers.
[23]
L19[edit]
From 1991 the 454 was updated to the new Gen V block, crankshaft and heads. This engine was rated at 230 net hp, 380 ft lbs net torque, and was discontinued after 1995, GM coming out with the Vortec 7400 in 1996.
Generation VI[edit]
L29[edit]
The Vortec 7400 L29 7.4 L (454 cu in)
V8 was a
truck version of the Chevrolet Big-Block engine. Introduced in 1996, it was produced for five years, until replaced by the Vortec 8100. Although introduced as the Vortec 7400 in 1996, it was basically a 454 Big-Block with a hydraulic roller
cam, parts more suitable for use in
light duty trucks, and more advanced technology. The engine had MPFI (multi-port fuel injection), which gave slightly more power and better fuel economy, and 2 valves per cylinder. The engine had a bore and stroke of 4 1⁄4 in × 4 in (108.0 mm × 101.6 mm), producing 290 hp (216 kW) at 4000 rpm and 410 lb⋅ft (556 N⋅m) at 3200 rpm.
L29 Applications:
