I recently rebuilt my carb because of a stuck needle and it's no longer flooding but I'm now having an idle issue. Stock 84 Hurst olds 307, previous owner put in a power chip, not sure which one all I know is it requires 93 octane. The idle will wander a few hundred rpm normally between. 1200-1500 but when I let off the gas it trys to die out or it likes to idle close to 600 when I'm trying to go slowly up my driveway (slight incline) I have been able to solve the problem by doing one thing, disconnect the TPS. Took it around the block with it disconnect a few times and it runs amazing. Any idea why it is only good with the TPS off. I'm still trying to understand the computer system on this car, I believe it controls timing and the smog equipment and the tcc solenoid, what else does it do that's important?
