brushed the snow off the car cover ( the hood portion at least ) and hooked up the battery tender. Christmas is done ... is it spring yet ?
I am sooooo temped to put the car on a tilt-n-load ( making it dock level ) so I can take it to work for the rest of the winter
Reactions: Northernregal
Built a piston stop... which I quickly learned only works with flat top pistons. Need to make a longer bolt.
Been fiddling around with the choke setup on my motor. Decided to go all "factory" and use the oil pressure sender method. Got a brass T fitting (needed to grind down a bit, would hit the block) and plumbed my oil pressure line into it as well as a two terminal sender. Elongated the factory power wire and made a new choke wire. No dice. Hooked the choke wire to the battery and the choke itself, nada. Ordered a new choke coil, should be here in a few days. Also, I got this little GPS drag racer app on my phone that uses your location to do the 1/4 times. I felt froggy and on a stretch of 55mph road near me I whacked it, and it said I moved a 1/4 mile in 13.89 seconds at 97mph. Now, as much as I'd like to believe that, I need to do some backup runs. lol. Trans shifts nice. Still haven't gotten around to hooking up the kickdown cable, but shifting manual it's almost instant. Also, I need to make my heat work. You know it's cold when your pop from the burger place is colder once home than it was when they gave it to you.
Went on a drive today, my brakes felt weird. The brake light was coming and going. I thought "Oh that vacuum hose is probably popping off", as I've had that happen before. Nope. All my fluid in the front reservoir is gone. And there is a dark puddle of what looks like black coffee where the rear end of my car was a day or so ago. So, need to find the leak, probably near the rear end, and fix it. Might as well replace the rubber hoses up front as well and now is a perfect time to replace all my missing brake fluid. :L
