So finally got at the Monty, non T-roof but the floor carpet was wet from front to back and both sides, so ripped it out, floors all still solid, Thank-God!!
And got at the Olds, rear window trim back on, head liner removed, dropped over winter an old hood off, now to but the new 442 on!
I really got to start driving them cars!!
Yesterday actually, giving the tailgate a work out.
How are you doing, Paul?
I hope you've been recovering well. I know it's been hotter than Hades out west. It's been the opposite here...raining everyday.
Doing better I got some antiviral meds so I am healing up, look like hell but feeling much better.
That's good to hear. Hang in there old man.
Reactions: Rktpwrd and tc1959
Today, I accidentally made it worse. I took the t-tops off and rolled the windows down to air it out. Somehow I think the sunlight (it was about 95 degrees) reflected off the open hood and melted the dashboard. I have a few bubbles on top where it was perfect before. The dash insert fared worse, I will buy a new wood grain insert to help but it feels bad!
Afterwards we did make it out to a local car show, we drove 30 miles in to a thunderstorm that was coming. I left the roof panels at home so we turned around right after.
i noticed a few weeks ago that the rear bar was moving within the bushings and getting close to the lower control arms.i installed a set of shaft collar bushings to limit the side to side.it was a good easy fix.
i also finished up all the a/c lines,that ez clip system worked well.i'm waiting for the hose seperators to replace the zip ties for now.
Went to replace the old radiator with a new one and electric fans.
Once the old was out I decided to change the belts
Once the belts were off I said i might as well change the water pump while everything is loose.
Store doesn't have 2 out of 3 belts and of course no water pump in stock.
So now it sits ......:blam:
On a good note I switched out the clear marker light with an amber set.
I think I makes a huge difference...........In a good way.
