i pulled the o-ring adapters and hoses from the steering box,brake cleaned it all down.one of the rings was a stretched and had a flat spot(??)i replaced them both and ran it for a while.no leaks so far.maybe that was it who knows.there's a h20 ban here so I'll go to work tomorrow and jack it up and clean the underside of it all.gonna try some foamy see how it works.
Ordered a '79 Cutlass assembly manual cause it's the only one out there for our cars. When I get it I might need some of you Olds guys to translate some stuff into english.
I love mine. It's about 95% accurate. Which is great. There is a ton of info in there.
I have to mask the red off and shoot the black again, then add some silver to it but this is gonna come out real nice.
What I did with mine was get an oil pressure sender from a 1990 Chevrolet 1500 truck and a matching pigtail from the parts store.
That sender is a combo of a gauge type oil pressure sender and a oil pressure switch in one unit. The center pin goes to your oil pressure gauge, and the outside two pins provide the switching. I tapped the power wire to the HEI for one side, and hooked the other side to the + terminal on the choke cover. I have mine pointed straight towards the brake booster, and it is nice and out of the way.
Nice idea. All the ones I have are either single tab or dual tab. Phoned Napa and he says he has a dual tab that will screw directly into either the one stock ell or both of the ones that I custom created in a combination of S/S and Brass. The factory dual tab is an AC unit with a part number on it that they may be able to trace. Wonder if they have a dual tab plug in a box somewhere. With just the two tabs I could still wire up the gauge and use the other tab for the choke. Ground is through the body to the engine so that is okay. Only complication is that It is getting to the point where if I am in a store for more than 5-10 minutes, unless it's a grocery run, I start getting way antsy and looking for the nearest exit, purchase or not.
