Uh...that's not a GTO.
This is its twin sister. Doin work.That doesn't look like too bad of a fix. You should show us how big that monster really is!
Wonder how much power it takes to run that fan?got a 97 C3500HD.. freshen the 454 up, been working at updating the cooling system.... mainly the fan... and thermal fan clutch..
swap in a hayden clutch, does well, better than stock... AC at idle sucks... air flow is drastically reduced.. pre condenser fan would hold a 3*5 card at the edge of the radiator at idle
OEM fan is 20" 9 blade with 25* pitch and 1.75" thick blades.. assuming pitch is measured angle in a straight line from leading to trailing edge of the blade..
to a derale 20" 6 blade, 27* pitch and 2" thick blades.. pending mounting bolt circle... pretty sure 3.5" is a typo and is suppose top be 3.25"..
currently running solid hub 19" 6 blade flex a lite which move substantial more air than OEM setup... holds said card up easily, also pulls ~50* out of the condenser at idle in 80* ambient between inlet/outlet ports
im sure the 6 blade will talk more when engaged than the 9 blade will
https://derale.com/product-footer/b...everse-rotation-fan-clutch-fan-black-1-detail
Good bit lol. All it does it drag a GN trailer around..Wonder how much power it takes to run that fan?
View attachment 114896 this one is close to me. Perrine bridge. Travis Pastrana jumped from an RV while it was driving over it. It's legal to base jump from it too.
