CUTLASS What front ends are interchangeable?
20,397
aren't the lights you're talking about in the header? I think the lines on the Supreme header are the same so I think you could replace the header, grills and bumper
grandamman
809
415
up in the hills
What’s up guys. Greetings from San Diego. I have an ‘85 Cutlass Supreme Sedan. Wondering if the front end (before hood and fenders) is interchangeable with say, an el Camino, or wagon or even a 2 door coupe? I’m trying to find a front end that will get rid of the turn signals to the side of the headlights. I noticed other g-bodies, including the wagon, don’t have the side markers. Thanks in advance. 👍🏽🤓👍🏽
Hey Eddie, Sorry but I can't help answer your question. It sounds like you are looking for a different model and or year header panel (nose assembly) that will fit your 85 Cutlass Supreme Sedan.
I would think one of the Cutlass guys would help you out.
You may end up needing to swap out the entire front end...fenders, hood and header panel.
The new fenders would need to match up with your doors....
Eddie Cutlass
May 3, 2020
78
62
San Diego
Yeah, they’re the corner park lamps/turn signals in the header. I dig the look without them. Just curious if anyone knew if other front clip headers bolted up and matched/semi matched the fenders/hood so that I wouldn’t have to replace the entire front end. No biggie. Can’t wait to start taking it apart.
oldsmobile joe
2,067
3,053
mpls
78-79 cutlass cruiser wagon, cutlass salon coupe and sedan header is what your looking for. The 78-79 header has no side marker lights. Instead, the side marker lights are in the fenders. Up to you if you want to swap fenders also. 78-79 header should bolt up to your fenders. Here are pics of my 78 salon coupe and 79 cutlass cruiser wagon. Is this what your looking for?
Eddie Cutlass
May 3, 2020
78
62
San Diego
View attachment 148344 View attachment 148345
Yes! That’s it!
sweet rides, by the way!
I’m going to replace the body bushings and while I’m at it, I figured I would see about switching the front header if it wasn’t an extensive mod project and clean up the frame and Spray on some under carriage coating...I lucked out the car has only some surface rust here and there.
9,617
12,697
Just so you know there is a law in place that requires side facing amber marker lights in the front so if you change your header panel to one that doesn't have them you will need them on the fenders.
It is a safety issue so other cars can see you from a side profile, they are not there for show.
Eddie Cutlass
May 3, 2020
78
62
San Diego
Mos def! Yes, I learned this the hard way with my s10 I modded a few years back.
JAMCAR223
1,853
5,507
Houston, TX.
If you can't find the Salon header and fenders locally, I have them in Houston
