What is the cheapest possible ls swap?
D
Djdavila1
8
5
#1
What is the cheapest ls swap you can do? i have a Pull a Part that i can pull a ls for 180 so how can i save more money. i have zero issues getting used stuff
383_GrandPrix
383_GrandPrix
364
378
Quebec, Canada
#2
$180 for an LS is pretty good, but even if you can find cheaper, buying the engine isn't the expensive part; it's everything that comes after.
D
Djdavila1
8
5
#3
yea i have found that is the biggest pain but idk where to go and what to do im broke and im stuck with a 403:blam:
TURNA
TURNA
6,016
7,423
Socialist NY
#4
A stolen one!!
383_GrandPrix
383_GrandPrix
364
378
Quebec, Canada
#5
You should introduce yourself in the new user section, let us know what you have and what you want to do.
fleming442
fleming442
4,598
4,624
8
81cutlass
1,394
1,679
Western MN
#7
Look up this video series "Extreme cheapskates turbo LS edition"
He runs 10's for just a tad over $1,000, granted he does run a shop but-
LS swaps can be very cheap or very expensive. Depends on how pretty, fast, or reliable you want to be.
Streetbu
Streetbu
725
1,229
Central NY
#8
Forget the headers, run manifolds. Do the wiring yourself, farm the PCM out for $75, run a Corvette fuel filter/regulator, frame rail mounted pump. Lots of fab work, but it's doable. If you're not completely comfortable with anything I've said, you won't do it for less than 2k let alone 1k
Opie Knievel
Opie Knievel
Whiskey Fueled Midnight Mechanic and Moderator
Moderator
Sep 6, 2010
1,495
1,737
Brodhead, Kentucky
#10
the cheapest possible swap is forgo the LS and get a Vortec SBC from the previous gen suburban/Tahoe/pickup that is probably laying there, unwanted right next to it.
I agree with you to an extent. It depends on where you are as to how unwanted that small block Vortec engine will be. When I worked at the junkyard (I'm in KY) I remember how rarely we would get a Vortec in and when we did they were usually priced pretty high. The last reasonably low mileage Vortec engine in stock was priced somewhere around $900. I'm pretty sure that I could have gotten a 4.8 or a 5.3 for less than $600. Of course a pull your own place would probably be a lot cheaper.
As others have already mentioned, the engine itself can be acquired for a reasonably cheap price but it's all of the other stuff you need that makes the cost go up quickly.
Similar threads
