This is a wiper motor park relay. It looks close, maybe some stuff busted off? The wire tabs would normally stick out of the housing. How many wires on your wiper right now? Does your wiper motor park properly?
pontiacgp said:...it can't be a relay with only two wires
pontiacgp said:I'm still thinking it has something to do with an alarm, like the motion detector....if you have a multimeter put is on the continuity setting and see if the two connections set it off when shaking the part..it can't be a relay with only two wires
custom442 said:pontiacgp said:I'm still thinking it has something to do with an alarm, like the motion detector....if you have a multimeter put is on the continuity setting and see if the two connections set it off when shaking the part..it can't be a relay with only two wires
It could very well be a relay. Two wire relays are common in computers and appliances. A ptc relay is one example. It works as a switch with resistance and doesn't transfer voltage to the other side of the switch until enough resistance (heat) has built up, this way full and constant torque in electricity is applied at all times (to the device/motor) regardless of temperature, weather, and voltage/amperage differences in the wires or charging circuits. This could be how the opposite NTC relay works :?: I'm no electrical engineer but you can kind of gather how they work
I'm not saying that is one I've never seen anything like that in the picture, but it could be a relay just as well as anything else. I'm sure 2 wire relays back then were much bigger than today.
