What's the pitman arm part# for a fast ratio gear box??
moose
188
16
ICT, KS
Got an '85 Monte SS remanufactured fast ratio steering box for my '85 Cutlass (800 series, 4 bolt top). Thought they were a direct swap out on any Gbody, but I've been reading conflicting info that the hole sizes are different in the pitman arm on different models. The part# on my pitman arm is 7828464 + 3. I can't find any SS models around here or else I wouldn't ask.
Will someone with a fast ratio box please post the part number of their pitman arm?!!
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,195
9,848
Gainesville, Fl
You need a pitman arm from (or for) an 800 series box for a G-body car, of course. The 605 series pitman arms will not interchange with the 800 box.
Otherwise, I believe the shaft sizes are the same between 800 series steering boxes.
moose
188
16
ICT, KS
Thanks Longroof, I do currenlty have an 800 series in my Cutlass. I just want to feel 100% confident my pitman arm will work before I take parts off.
Longroof79
Oct 14, 2008
12,195
9,848
Gainesville, Fl
Pull the pitman arm from your existing box and install it on your new box...I think you should be good to go. Your hoses should also be a direct replacement. Go for it!
tc1959
3,963
1,975
Surprise AZ.
Ya me too, I pulled my pitman arm off my Original box It has no moving parts , Reinstalled it on my IROC- Z box. Took it to the shop and set up the FT end No problems.( I also replaced all the other FT end parts at the same time). No Worries.
tc1959
3,963
1,975
Surprise AZ.
I have a F-Body 34 MM sway bar, MY tires just barely touch the bar on Lock To Lock turns.
We road trip this car alot It drives really nice. Getting her ready for a Route 66 ride next month.Can't wait....
G-Body_Vet
2,937
81
48
What size tires/wheels/offset are you running? I have the 34mm bar too but I have the oddball 2.25 lock to lock box.
pontiacgp
blank
Mar 31, 2006
29,270
20,419
Kitchener, Ontario
he's got the Z box, same box you have and the same box I have and they all have the internal stops which gives the 2.25 lock to lock, that's why his wheels barely touch the bar...
Longroof79
Oct 14, 2008
12,195
9,848
Gainesville, Fl
I think I may be plagued with some rubbing action once I put my 36mm bar on. I have the Monte SS box which does not have the same stops as the WS6 box. iirc, my steering is like 2.5-2.75 turns lock to lock.
Even with my current 32mm GN bar, there's still some tell tale signs of the tires rubbing against it.
moose
188
16
ICT, KS
So you guys convinced me, I'm goin for it! Thanks
