Chris Van said:rccktmn2 said:First off the GM 4 link rear suspension is not designed correctly to plant the rear tires and eliminate the wheel hop. If you take the upper rear control arms and the angle they are on they never cross the parallel line of the lower control arms. If you put in no hop bars or something similar it will raise the upper control arms making them intersect the parallel line of the lower control arms and essentially trying to pick up the front of the car on take off eliminating wheel hop.
I know what you are saying sounds logical geometry wise anyway.... but from my personal on track experience I have to disagree. The no hop bars did not work for me. The car was inconsistent as hell with the no hop bars and rode like sh*t too. I took them off, with no other changes, and the car worked again.
My suggestion to the question first would be to put new shocks on the rear. The rubber bushings couldn't be helping either. My car 60 foots in the low 1.40's with the stock geometry suspension setup. Over time I did add adjustable upper and lowers but they are set exactly like the stock ones that came off. Only difference being that they are now solid verses having bushings in them. I am also running a pair of $20 dollar gabriel shocks.
I agree with the rubber bushings because as soon as you put torque to them they flex way too much and I agree every car is different but I've seen some dramatic improvements just by changing the angles of the control arms on the rear.
http://www.baselinesuspensions.com/info ... ag_Car.htm
Here's a website that explains all the geometry of the suspension, Dave Morgan also wrote a book called door slammers that explains it as well and if you check out most of the tubbed or non tubbed 4 link setups you'll find the upper control arms are pointed down in the front toward the front of the car and the bottom control arms as level as you can get them or slightly upward to get the most weight transfer you can to eliminate the wheel hop and plant the rear wheels.
