Where to put he PCV valve Buick 350.
6,837
6,755
On my used cast iron 4 barrel intake, it came with a grommet in the back of the intake for a PCV valve. Wen I got the intake back from the machine shop, they gave me a pcv valve. Does it matter if it goes on the intake or the valve cover? Does that mean I could run a breather on the VC and the PCV on the intake? The intake is from an early 70s buick 350 with divorced choke. Engine is a 1976, was a two barrel.
10,578
14,323
I prefer the intake so as to get a good suction where it matters- the crank case. Every time I see an open breather on the VC, it seems it leaks oil. Remember, the factory used a two stage PCV system. The intake sucked blowby gasses whenever there was good manifold vacuum, which is most of the time. BUT, when the manifold vacuum drops to nothing at WOT or other times, then the breather plumbed from the VC to the air cleaner takes over since there is good velocity through the carb. Without the air cleaner connection the blowby has nowhere to go but out the VC breather taking oil with it. The factory used that little foam oil separator in the air cleaner line to catch the oil before it could foul the carb. Obviously a tight motor will blow less, and a sloppy motor more.
12,178
9,797
I agree. I'm sure Buick put it in back of the intake for a reason.
6,837
6,755
Is there a place I can buy the little oil catching thing for the air cleaner? Is it like a specialty part? I do not have the factory air cleaner. I want to get the big old black housing for that stock look.
10,578
14,323
Pretty common item. Go on RockAuto and search for this- "BUICK 1976 LESABRE 5.7L 350cid V8 Emission Crankcase Breather Element". Some as low as $.25!
6,837
6,755
so does that mean i need two pcv valves?
G_Body_Enthusiast
1,056
16
38
Louisville, kentucky
Negative Ghostrider. The pcv valve goes into the intake and on my V6, the hose from the PCV valve goes to front of the carburetor. The other side of this system is a short piece of hose that connects a valve cover (passenger side for me) to a breather filter in the air cleaner.
  • Useful
6,837
6,755
Oh, gotcha. I keep forgetting I still got my '6 around to look at for reference.
6,837
6,755
I found this on summit, same thing. Might order that one from rock auto along with a water and fuel pump for my engine, maybe even a timing cover if they're cheap. http://www.summitracing.com/parts/hht-cb14/overview/make/buick
I have never seen this thing before in my life, where does it go exactly? I know it goes somewhere on in the factory air cleaner housing, I just don't know where.
v2vera
710
41
in the Desert!
It goes inside the factory air cleaner on the passenger side.held together with a "U"clip. Then a hose from it into the valve cover.
