Which head gaskets?
Which is better?
  • Mr Gasket MLS .040"
    Votes: 1 100.0%
  • Mr.Gasket .045"
    Votes: 0 0.0%
  • Mahle .040"
    Votes: 0 0.0%
  • Good old Felpro Blue .042"
    Votes: 0 0.0%
  • Total voters
8,998
8,126
I am finally getting back my 358 short block tomorrow, a year and a month. I have 4 different sets to choose from. I am planning on using iron #6 heads and my Performer cam. One head is 62CC, the other 64cc, previous owner knicked a deck in storage and got one cleaned, why there is a variation, wanting 66 to 68cc for under 9.5 to 1 compression. Heads were fully rebuilt with upgrades, better springs, 2.07" intake valves, bowls opened and positive seals with maybe 5000 km. The block is very close to 0 deck, .016" was removed to square it with a 4.100" bore 10cc Mahle forged pistons, Molnar rods and 330 crank. I have Mr.Gasket MLS .040" in a 4.100" bore but I plan on keeping them for a possible aluminum head swap. Or are they OK with used but previously milled iron heads? I have 3 other sets, Mr.Gasket Ultraseal .045" that mentions painting the metal side with two coats of aluminum paint. The other sets are .042" Felpro Blue and .040" Mahle regular head gaskets. I am learning towards the Mr.Gasket. 045" so I will have to polish the chambers less. Just strange that one side is all metal, anyone use them?
Edit Quote
If the block deck and head surface are good, then it’s hard to beat an MLS.
Yeah, I agree. But the the head surface isn't perfect, has run time and won't be milled again, already too small of CC. Plus no more machine work for a while, $2270 to fix my boo boos, the other machine shops and assemble it!
I haven't found the need to go beyond the Fel Pro blue gaskets. We used them at the machine shop on many questionable engines. I ran the fel pro 1057 gaskets on my 15:1 565 so they work. I have the 1017-1 gaskets for my 496 for the Chevelle.
